Bad day on brakes..........
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
Today I thought it was the end or close to an end to my front axle swap to a front disk brake system.
The front is mechanically on.
New rotor, new rubber hoses, new master cylinder, new proportioning valve. The old lines were cut and flared, new lines were spliced in to the proportioning valve that is now up attached to the master cylinder.
Reay to go. The master was plumbed with short lines routing fluid back into the MS reservoirs. The master was "bench" bled in the vehicle. !!cool! The lines were attached to bleed the entire system. Working the slaver cylinders in the traditional way ....pump .... pump .... pumppumppumppump ... Nothin'!
So off to the store to get a vacuum bleeder. suck ... suck ... suck ... NOTHIN! And to add to the frustration now the pedal stroke is catching and not right.
........ Not a good day. Where to next?
