Ball Joints
hole
Crazy Sr. Respected Jeeper
- Media
- 28
- St George Utah
- 83 CJ 8, 258 I6, T19, 4-1 Dana 300,4.0 Head, Mopar MPI, 10k winch, OME YJ springs w/3" lift,CS 144 Alt upgrade,Locked 20 & 30, Border Collie co-pilots are stock.
The axle shafts are held in with snap rings inside the hub assembly IIRC, Once the hub is off you pull the spindle and the shafts should pull right out. Inside the hub (and spindle too} is where you may find your bearings need replacing after clean up, or not and just repack with new grease and re-assemble. The seal at the back of the hub will need to be replaced if you do completely disassemble the hub, but I've seen plenty of guys be lazy and just pull the hub and re-install it without fully taking it apart to clean and check the bearings because their mindset is they didnt hear any noises, so the bearings are just fine.
