BDS YJ Conversion is on
cuban11182
- CORPUS CHRISTI
- 84 CJ7: 258, T5, Dana 300, Holley 390, Nutter Bypass.
I know it took a long time to get it installed due to life (college, work, weather, etc) but my buddy and I installed it yesterday. Took a lot longer than we thought it would, and ran into a few snags. First: read the directions before-hand, it'll save you problems later. Secong: make sure you don't lie in an ant hill of biting ants. Third: run with a sway bar!
I'm pretty sure this was the original suspension, so some of it was a pita. Front driver side was alright. Just grind the rivet and place the new hanger. They have these spacers if you want to run an oversized bumper, but mine is still stock, but I kept the plates (just in case). Since you are using YJ u-bolt plates it comes with two studs, one for the sway bar and one for the shock. Problem is that the stock shock mounts on the front axle interfere with the shock going into the plate. On the drivers side this wasn't an issue and I placed the shock in the old location. On the passenger side I had to cut and grind off the old mount so that the ubolt would go on straight. Sway bar upper bolts would NOT come off. I pulled it off for the short time being. New parts have been ordered to throw it back on. Rear was easier, but time consuming. My advice is to put on the body mount bolt on first, then attach the shackle mounts.
As to the ride. I've only taken it about 10 miles or so, including a small (2 mile) trip on the highway to work. She is still bouncy, but it's a much smoother bounce (if that makes sense). It doesn't jar you all over the place. Driving at 45MPH and below, you can feel the sway bar is not there. On the highway she is super twitchy (it's always windy in Corpus) and I'll be putting it back on once the parts come in.
Picture to come.
Picture to come.
