Best fuel pump for 1981 CJ7 4 cylinder 2.5L (GM 151)
PapaBear
- San Angelo, Tx
- '81 CJ 7 Named Rosie 4 cylinder 2.5L GM 151 dana 300 tc t18, '59 CJ 5 named Ocho also 4 cylinder same scenario as Rosie do not have a clue. I am a plant guy that is addicted to jeeps
As the title hints, I am looking for some info on the best fuel pump to go back into my jeep with. I am not 100% sure that it is bad, but I have replaced everything involved from there back and added an in-line fuel filter, cleaned the carb (weber 2 barrel) and it has started dying on me at stops (i.e. when stopping at a stop sign, stopping to look at animals on the ranch, parking) it also dies when I am slowing down, but I down shift and it fires back up. Help with the initial question (what is the best fuel pump for my baby?) and any info on what might be causing this problem. Also, it seemed as though this problem began with the addition of my fuel filter between pump and carb. I have checked the filter and it is clean. It did it right before I added the filter but the filter in my carb was all gunked up thought that was the cause of that so had gas tank cleaned and added fuel filter and cleaned the carb. also added a new sending unit. (sigh)(help)(please)(thanks)
