BFGoodrich 32x11.5x15 tires
grunt
Connecticut
1979 CJ 304, 400 automatic
Got a great deal on Craigslist for 4 tires. BFGoodrich 32x11.5x15. These will go my CJ which has a 2 inch spring lift and body lift. I have 33x12.5x15 on my jeep now which are toast. Can I use the same rim now or do I need to get different rims? If I can use the same rims I imagine the tires will look way shorter in height? If I get a narrower rim the tires will look taller? Any pics or any info would be appreciated. Thanks.
you can use the same rims. one inch shorter and one inch skinnier wont look bad at all.
put the 33 against the 32 they are about the same height
I have a set of 32 bear claws they are actually about 1/4 inch taller than my 33 bfgs every manufacturers size vary s slightly
Those are 8" rims on mine. Had to go out and measure to be sure.
My 81 CJ7 has about the same lift as yours, and is running 32x11.5x15 BFG KM2. Love em.
Yup, me too! No miles on them yet but size is perfect more my taste.
