Body mount question w/pictures
Colo Dean
Greeley Co
74 CJ5 258 I-6, 4 spd T-18, Dana 20 T/C, Dana 30 Front, Dana 44 Rear 4.27:1, still learning everything about this one, 14 JK pretty much stock
So I am working on the body work and replacing the body mounts with poly mounts. On the rear there are 4 mounts, 2 outboard and 2 inboard. I got the outboard ones out but ran into an issue with the inboard mounts. While trying to loosen the bolts, they would just turn. Initially I thought they were threaded into the support piece behind the rear valance/body panel. We tried lifting the body hoping that while turning the bolt we could get it to come out. That is when we noticed that the body lifted right up and there was a nut but it was under the bushing. I have a photo with the wrench on the nut between the rubber bushing and the rear cross member. Is this normal???
I also noticed that some mounts are installed with the rubber against the body and the fender washer under it. Others the washer is above the bushing. Is there a right or wrong way to install the new mounts? On both front mounts, it has rubber above and below the frame mounting arm rather than just a washer and a nut. The lower rubbers don't look all that bad, should I re-install these?
Last question.....for a while......after counting the remaining mounts in the package, it does not include enough for the grill. Is this normal when ordering a body mount kit? I purchased the Daystar mount kit.
Thanks in advance for your advice.
For your first statement, no, it is not normal. The frame must be bolted to the body with the pucks in between and have a washer against the frame to help distribute the load. Having a washer on both sides would work if you can get enough. It also sounds like you are a little short with the pucks so just put one of the good ones back in there. If you have rust in some of your bolt locations, you might want to install a stainless bolt in there.
