    To dismiss this notice
    click the top right X.
body tub match
From info Ive gathered the dimensions are the same but there are a few differences. The windshield defroster vents need a little modifying to work with the Cj windshield frame.
There are 2 body mounts that need to be moved as well. The fuel filler is on the wrong side so you have to patch it up and cut it out on the correct side.
If you want to retain your fold down Cj tailgate you have to modify the tub in the rear to accept the hinges. The Yjs tailgate opens to the side.
Heres a good write up on the Yj tub swap. Pretty popular swap:
certifiablejeep.com - Third Project Build-up - Conclusions
Thank you so much for your usefull Information on my body tub swap with your help my 78 CJ7 will be looking good again I will try to keep you posted on my progress again thankes alot for the Info pinky:)
I am doing the same thing.... i have read four of the builds on the certifiable jeep website and it is full of information... kinda like a play by play and let you know what he was thinking and how he tackled some issues...
CJ YJ Tub Body Swap Link Listing - Page 3 - JeepForum.com
I included this thread due to the diagram i found about half way down the page should take care of the body mounts that you will have to replace. also at the bottom of the thread you have other links to see how people have used a cj dash and other things...
$40.00
  20.0%
