body types
reptile610
- st. clair shores, MI
- 1982 CJ7: 151cu iron duke/ sr-4 trans/ dana 300/ dana 30 front amc 20 rear 3.73 gears.
so i have a CJ7 and the body is in pretty bad shape, going to sand it down this summer and see exactly how much damage it has. if i end up replacing the tub whats everyones recomendations? i see the cheapest is a fiberglass tub, next would be aluminum, and the most expensive would be a stamped steel tub. i hear fiberglass is pretty strong and light but that you have to do alot of extra work to ground your electrical, aluminum i work with at work and not sure which type it is but i personally think it's pretty soft and but it's lighter than steel. a steel tub is obviously heavy and they're about 3k for replacements. whats everyone have and was wondering what the inputs are for pros and cons.
