Brake Combination Valve?
Torxhead
Always Off-Roading Jeeper
I have recently noticed my brakes seem to be on while driving from time to time. When I let off the gas to slow down the brakes seem to be already on. I have also noticed the metering pin on the combination valve does not stick out as much as it used to, so I'm thinking thats what it is and letting the brake fluid have a slow return. I have removed that metering pin and it does not seem to have any crud on it indicating a clean system. I really don't think that the brake lines have collapsed, since they are not that old or the calipers sticking since it slows down in a straight line, but they are the oem brakes if you can believe that. Any thoughts?
