    Thank you for your support!
Brake Lights
Brake Lights
Well it looks a little different than your pic but THANK YOU- I was able to identify it based on your pic! I didn't lose it and it seems to be operating ok.
This electrical thing is hair pulling.
I can't seem to create the same situation twice.
Now I have tail lights no hazards or brake lights.
The brake/hazard/turn signal lights, are all routed through the turn signal switch.
Well after adding grounds I now have brake lights and hazard lights but now no reverse lights and the "brightness" of the brake lights is not correct. When the running lights are on there is no change when the brakes are engaged. So I am good to drive forward during the day :)
I am wondering now if the issue is the turn signal switch.
Any suggestions?
Reverse light circuit runs separate of all others.
99% of the time the reverse switch within the tranny is dead.
When you order a new switch-Order 2.
Turn signals-Try a new turn signal flasher.
Thanks so much. I will try those things!
I really appreciate the feedback.
