brake pedal stick when pressed down
1986cj7
- Media
- 15
- southeast missouri
- 1986 cj7 258, t-176 4-speed, d-300, moser one piece axle in back in amc 20,G2 4.10 gears front and back, detroit truetac front and back,G2 4340 chromoly front axles in a d-30, 4" rough country lift, 33" tires
I have replaced my master cylinder and now the pedal sticks, I have to use my foot to pull it back up. I've tried spraying WD-40 on the shaft of the master cylinder and the pivot point of the pedal up by the return spring. I replaced the cylinder because it was leaking. Could I have gotten the wrong cylinder? I haven't replaced the pivot bushings doesn't seem to have to much play in it. Any ideas?
