Brake system rebuild questions
hollasboy
Have had nothing but problems with my braking system ('79 CJ5 Renegade ) since I bought it last year - very hard pedal, long time to stop, parking brake doesn't hold anything, rear drums cracked, etc. So I decided to get all new parts and rebuild the whole system from ground up and with all new parts. I'm 75% done with that, but have a few general questions about the brake system as I near completion.
1. Low brake indicator light. I bought one of those wiring diagrams as recommended on here, and it shows a "Low Brake" warning light coming from the proportioning valve. My old P-valve has a female wire pin on it with more than 1 wire (can't remember if it's 2 or 3 wires total) going up into the engine bay, and the replacement part has the same pin to connect wiring. However, during my dash rebuild and wire clean up, I never came across any such indicator light or wiring. Was this standard? Should there be a brake warning light somewhere?
2. Parking brake indicator light. Is there supposed to be one? The parking brake pedal assembly that I took out did not have any kind of electrical components/contacts/switches/wires, but the new replacement came with a copper contact which I presume goes to the indicator light. Should there be one of these indicator lights somewhere?
3. Proportioning valve port thread size - the new P-valve I bought matches the old one exactly, EXCEPT the female threads going to the rear drum brake line are much larger size than the old or new rear brake line. Can I just put a brass adapter fitting on it to reduce the thread size so the brake line will fit, or will that have repercussions on the braking system?
4. In a couple places on the driver side chassis, the rear brake line was secured with a loop bracket, along with 2 other rigid lines (bundle of 3). What do those lines do/go to?
5. Adjusting parking brake - since I replaced the rear drums, springs, wheel cylinders, pads, etc. AND the parking brake cables and foot pedal, should I wait to adjust the parking brake tightness until after I've bled and activated the brake system? Not sure if I tighten it to just the right amount now, then later stomp on the pedal, pushing out the pins in those wheel cylinders for the first time, if it will get too tight in there and mess something up.
6. Bleeding entirely new system - I've seen lots of comments about having to hold in the pin on the P-valve when bleeding a system, but not enough detail in any comment to guide me on how to do it. I've also seen some comments saying don't worry about the pin and just do the bleed in Front-Back-Front order and it will work. What is the final answer on this issue?
7. P-valve adjustment - I am pretty certain that the P-valve comes from the auto parts store pre-calibrated - is it necessary to adjust it? If so, how is that done?
Thanks!
Thanks!
