Brakes and such
somedude922
- Mckinney, TX
- 1979 CJ-7 Golden Eagle AMC 360, TH400, Quadratrac, AMC 20 and Dana 30 narrowtracs.
Here we go. So over the last few weeks I have noticed a tapping sound coming form my front left wheel while driving, goes away when braking. I tightened everything down. I noticed that when I spun my rotor with the wheel off, the caliper would move, kind of like a warped rotor. I figured ok, brake job coming. Well, now my wheel taps and when I brake its even louder. Take off the wheel and see the rotor is BENT, I mean bad, the caliper has blown its seal too. SO. I will be replacing all that. I have not worked on brakes, axles, hubs, bearing, seals and such before.
This is on a '79 with front disc brakes.
Questions:
Could it be more damage than the rotor? bent spindle?
What should I replace while I am in there?
Should I tear it all the way down and do ball joints( which look good), seals and bearings?
I need to acquire some tools. What will I need?
I am not a complete noob to wrenching but have been out of the game for a while, also I have never done any kind of work on axles of any form. Only engines.
I will try and get a picture up of the caliper.
Oh and I do have a original technical service manual. (not Chiltons or Haynes)
Questions:
