Broken horn button
Broken horn button
Duhwhat
Madison, Ms
1986 CJ7 2.5L 4 cylinder
T-4, Dana 300, AMC 20 rear end
I broke the little plastic spring loaded contact button in the steering column. Where do I find one of those? I have searched using 'horn button' but get mainly the center piece for the steering wheel. I am also interested in what it takes to get the plastic piece out of the steering column that holds everything in.
If this doesn't make sense, I will post some pics when I get home later.
Also, I was going to buy a new steering wheel (probably Grant) and I see it needs an installation kit. If that includes the replacement for that spring loaded button and instructions on how to remove the old stuff, then I will just go that route.
Pull your part, just about any GM steering column.:D
Good point. Any thoughts on how to remove the plastic 'cover' without damage?
I think you need a spring depresser, borrow from Auto zone or but for $15
the manual will illistrate the procedure better than I can describe it. there is a split ring on the shaft that you have to remove with the pressure off the shaft spring. this thing does it.:D
Steering Wheel Lock Plate | AutoZone.com
If you have one nearby I'd go for the complete kit from Harbor Freight. I thought I'd never need one and have used it 3 times on my rebuild already.
Steering Wheel Remover Set
For removing the plastic cover, the best I can say is be careful and easy. The plastic is 25 yrs old and can be brittle. The three oblong holes are where it snaps. I took a small flathead screwdriver and slid between the metal and plastic and angled the tab away from the metal.
the previous owner couldnt get the horn to work, so he wired a switch on the floor that you step on. i kind of like it there. i have an automatic so i wont be stepping on it everytime i shift.
yeah, its kinda close. ill just have to get used to it
I'm new here. I have a 1985 CJ7 ... I'm the irina owner. I spent big bucks to get it derusted and maintenance updated. So now what I need your help.....
My horn doesn't work. I checked the horn, it's fine, checked the fuse, fine. I pulled off the steering wheel button - which didn't feel right - then took off the three screws and the horn button metal bowl (?). Under that, I find no wire or button. Looking at the few pics on this, it looks like the button that goes down to the blinker board (??) Is missing.
I plan on pulling the steeing wheel, but was wondering if anyone has a pic or 2 of what a 1985 jeep should look like under the steering wheel? ???
Thanks in advance!
James
PS... I'll try to upload a pic with the steering wheel on.
