Broken Intake Tab
SlopeStyleDJ
- Canada
- 67 CJ5
Buick 231 V6
T90 Transmission
Spicer 18 Transfer Case
Dana 27A/44 diff
So I just had my Dauntless Buick 225 V6 rebuilt at the machine shop, and I was reinstalling the intake when it all went terribly wrong. When I was giving the tenth and last bolt its final torque, the casting cracked. My Haynes book said 45-55 ft-lb, but I think it must be wrong. The tab that broke is the one on the front driver side, the tab that has been thinned to allow clearance for the distributor, and it also uses a Torx bolt for the shallower head.
What is the right torque setting?
How critical is the bolt in that location? Is it certain that my coolant will leak and wipe out the engine if not repaired?
Is it possible to fix the tab?
My old heads were shot and the machine shop rebuilt some newer ones, which meant I had to go with the newer intake that they boiled clean for me, and then i painted it. I'm hoping I don't need to source a new intake...
Any help or advise would be greatly appreciated!
