Build Thread Build a New Set of Gauges from Scratch
DHugg
MS Gulf Coast
'80 CJ7 304AMC crate with 8KMiles: MC2100 - AMC20 rear w/Superiors - Dana30 front - TF999 - Dana300TC - 35x12.5's - Tilt steer column - Flaming Rvr EZ-Steer Shaft - AGR Super Pump - AGR Super Box II - RockyRidge HD Brace - New home-designed digital TEMP - GAS - OILPR - CALIBRATE gauges.
Im going to leave this thread in the build forum for now. If everything works out I'll make it a sticky in the Electrical , body and chassis forum.
Re: Build a New Set of Gauges: What're we doing and why?
Can you run multiple sensors of a single board or do you need a new board for each sensor? I'd be interested in a single LCD scrolling display of temp, volts, oil pressure and fuel. I've looked at the Arduino boards before, but never got past the first look.
Can you post a more detailed wiring schematic and instructions when you get it all hooked up? Looks like a slick solution.
Peace!
Peace!
I believe you can do exactly what you describe. We'd use four input pins, and scroll through the presentations, writing the titles in row1 (fuel, temp, oil, etc), selecting a delay of a few hundred milliseconds between each data set, then writing the measurements in row2 as each sensor title was presented.
Once you grasp what the Arduino people have built, its capabilities, things like this are really not a challenge. As I test my own electronic gauge install, I'll post every step along the path.
The more I think about how this all works with Jeep panels and power wires, the more I think I need hinges at the lower edge of the dash panel, so I just unlatch the top and side fasteners and fold down the dash flat on the hinges.
I've never worked with Arduino boards but have been curious about them for a while and really looking for an excuse to jump in. This project may just be what puts me in since I currently have non-working Fuel and temp gauges, a fuel sender that as far as I know works, a suspect volt gauge since it's reading what would look to be 20v with the engine running and a used oil pressure gauge that isnt currently in the Jeep and no idea if it works.
Good luck and keep us updated. Would just being behind the dash be sufficient to keep it out of the elements or would it need to be placed in a somewhat dry box?
jpeck71, behind the dash oughta be the best place for it. Thinking today about where the best view would be while driving..... I may put an extra overlay above the steering wheel, angled out at top, and store it all there.
Anyway, my dash is so chopped up that anything would be an improvement.
