Ca. 258 rough idle
Sasquach
Crazy Sr. Respected Jeeper
- Media
- 35
- Santa Ynez, Ca.
- 1978 CJ5, 258 w/4.0head, Mopar MPI, P.S., P.B.,Tilt wheel, No stereo, t-18, t-20, amc 20, dana-30 w/tru-trac, Warn full float w/locking hubs & Detroit locker in the AMC.
1964 CJ3B, 4-134
1952 M100 trailer
After just completing the TFI ignition upgrade and while that made a very noticable improvement I still had a spot just a crack above idle were it would nearly stop running if you held it there, I am talking with the hood up and manualy holding the throttle. So since I just passed my smog inspection I though I would see if dissableing? anything would make it right, tried messing with the air pump(smog pump) and that gave no real results, next I pulled the vacum hose off the EGR and JACKPOT! runs like an engine should. Capped off the hose and between torrential downpours I ripped down the street and back with a smile on my face, so after going thru my manual to see if I could better understand this contraption and if I really had to have it I decided NO but thought I would toss it out to the forum and see. I did find I had no delay valve between the vacum line and EGR valve but why bother with trying to fix it?
