Can I put a YJ seat in a CJ?
Jeremy Martin
OKC
1984 CJ7, I6, 4 speed Manual.
I just got this seat to put in my 84 CJ7 . I don't have a bracket and can't find one. Someone else has to have done this, anyone have any suggestions?
You can do it. Ive done it in one of my prior Cjs. The Yj fold n tumble uses two brackets for the front that the seat slides onto. You have to be willing to drill your rear floor for these mounts. At the rear base of the seat you will see two round posts that stick out from the seat. These two posts slide into "C" shaped mounts that bolt to wheelwells.
You can usually find a complete set on Ebay for around $40-$50. I have a set of the front brackets if you want me to take a pic and post. The rear ones look just like Pac-Man! You just need to use some steel to reinforce the mounts so the bolts dont pull through the sheetmetal.
  5.0%
