carburetor options, help me decide
elwood blues
Always Off-Roading Jeeper
- Media
- 71
- Solutions
- 1
- Export, PA
- 1978 CJ7 4.2L Comp Cam & valve train, MC2100 carb, MSD ignition, Dana 30 front, T18 trans, Dana 20 txfr, AMC 20 rear.
Here's what I've got; a 1978 with a mildly built (cam) AMC 258 i6 / 4.2l . Stock it came with a single barrel Carter YF. The stock single barrel intake has been replaced with a stock 2 barrel intake off of a '79.
Currently I'm running a Barry Grant DEMON 350cfm 2 barrel on the 2 barrel intake. It's running way too rich, and has a stumble at low RPMs. Now, this could be a fairly simple tune job, but I'm a little concerned that this is not the correct carb for me.
I also have an Autolite 2100 1.14 sitting on the shelf, I was running this carb until I started the engine tear down, I believe it either needs rebuilt, or sent in somewhere to be remanufactured.
Also sitting on the shelf is a Holley 390cfm 4 barrel. Unknown mileage or condition, I traded a guy at work for it for two dozen of my wife's homemade chocolate chip cookies.
I also have a Clifford aluminum 4 barrel intake manifold, no not on the shelf, it's on the floor
So, if it was yours to do, which way would you go? I'm really on the fence and would like you all's advice, thanks
I personally lie the stock carb.
well you just cant beat FOMOCO carb since you can find a rebuild kit in every single town in USA and they are easy to work on, i have no experience with the Demons, the Holley you can rebuild pretty quick almost anywhere but not quite as easy as the 2100, is the ethanol giving you fits yet? My old Quadrabog would foul up and idle crappy from junk clogging it up, didnt do that prior to the ethanol craze, might be whats wrong with your MC, just junk gas
