Carter BBD Parts
Carter BBD Parts
Al Lindner
Richmond VA
1980 CJ 7 258 CID T176
2004 F-150
I need a vacuum piston assembly for a Carter BBD (what metering rods hang off of ) . What I REALLY need is a MC 2100 but if anyone knows where can get the BBD parts I would be grateful.
You will also need the spring that goes inside. You will also need to set the piston adjustment
The ck ball will be in a rebuild kit.
Good luck,
Good luck,
I know the check ball is in the Kit. What I need is the Piston assembly, the one in my BBD is damaged.
Finally fixed my Carter BBD! I REPLACED it with a Gronk Performance MC2100. WOW! what a difference Maybe the best money I've ever spent on a Jeep upgrade
  5.0%
