carter BBD swap to Weber 32/36 ?
Divepredator
Salem oregon
1984 CJ7 Laredo
I just ordered a new weber 32/36 and was wondering how hard is the swap.....Do I need to have a mechanic friend there to do it or is it simple enought for a farm boy to figure out with some mechanical ability..By the way this is my first attempt to do this form stuff.
Sorry for hijacking but I have a carb question:
I have a spare carb that came with my CJ5 and I am trying to identify it:
I know it came from AutoZone as a reman carb and it cost $160.99 in 2008. It has a part number of 64-1398 which translates to "2 bbl Holly Reman Carb Carter BBD". It does not have a tag on it but the body says "Carter Carbs 2425".
Any more info on if this is a useful carb to keep or should I just ebay it? Any idea on its value? Is it a Holly or a Carter?
I don't know enough about them but I would google all the #'s and see what you come up with. Sounds like you have already done some homework on it.
Your approach to this is interesting, not new I guess, but interesting. You may find, in the future , that finding out how to do a modification before ordering parts is much more cost effective than doing it the other way around.:D
Has your friend worked with Weber's before??
Have you ever worked with any carb before??
:cool:
Yes you are right but at the time I had no clue there was a web sight like this. I am a green horn when it comes to this computer stuff. But I am learning. This web sight is great you all have helped me so much on what I want to do and need to do. I am hooked on this sight. Now if I only had the money to do to my jeep what I would like to do life would be great. My weber runs great the jeep finally runs good. Although it does seem to run rich. But I havent installed a fuel reg yet.That is the next thing.
Understood.
Two things to remember.
1) we are here for you, we understand your addiction and are supportive of it.
2) There are a never ending list of things you can spend money on with this pass time, whenever you have the opportunity to NOT spend money, take it.:cool: You are going to need to rebuild/build whatever you can and it is still gonna cost a bunch of money.
have fun!:cool:
Thank you. I do read quite abit on this sight that is how I made up my mine on the weber. so I do take into consideration what you all say it is good stuff. thank's from Oregon
