Steering caster adjustment with a 2 1/2" lift
joeortego
texas
82 jeep cj5
Does anyone have an ideal of what the caster should be set at on a 82 CJ5 with a 2 1/2" lift?
Try for as much positive castor angle you can get after a lift. A lot depends on the shackle length too. You’re lucky to get
2 to 3 degrees. I think ideal is about 5 or 6.
The angle should be as close to the max as specified for stock. Specified is positive 5-7 degrees. Try to get as close to 7 as you can.
