Lift Kits How to I get to where I want to be?
jimonfly
Lawtey, FL
'78 CJ5
Check here for calculating amount of lift in various spots (body, springs, etc). Lift Calcs
Broken body mount bolts? Welcome to CJs. You may need to cut into the tub from underneath in the "channels" where the captive nuts are or through the floor from above to access them and get them out. This is quite common. When I replaced my body mount bushings, I had to cut into the channels from underneath on a few of them as the bolts were rusted into the nuts and broke off trying to remove them. I used an angle grinder with a cutoff wheel to cut a "tab" I could bend out of the way to gain access, then bend back over the opening and weld back shut. Saved going through the floor for me.
Those rear mounts with no bushings must be a great ride </sarcasm>.
The Superlift spring part # you mentioned states it's 2.5", not 5". What about shackles? Any extra length there? Stock would have been 3" eye-to-eye.
The Lift Calc link is how I calculated mine. 27.5" at the bottom of the rocker, less 18" stock = 9.5". I'm on 33's, which is 2", for 7.5", and there is 2" of body lift, which equates to 5.5" of suspension lift. The shackles are 4", not 3, so that accounts for 1/2" of the lift, leaving 5" for the springs. It also looks like the same springs are on the front and rear (all "R"), instead of the "F" being on the front.
I'll look at cutting into the channels rather than the floor. That seems less invasive and easier to cover up later. The videos I've seen going through the floor show a 4" hole saw, which seems hard to cover up later. I don't have carpet, and the floors are bed-lined.
And, yes, the ride is not great with the steel tubes on the rear.
I've seen springs add more or less lift than advertised. My rear springs claimed a 4" lift, but didn't provide that amount. I had to add longer shackles to achieve the lift amount I wanted and to match the front springs of a different brand. So wouldn't be surprised there. I also agree on the 4" holes in the floor. Also no carpet and just bed lined. In my case it was much easier to just cut through the channels and weld them closed. Slight grinding and some paint and all good.
Suspension Rough ride
$20.00
  10.0%
