Caster angle
yellow85cj
- Featured
- 1
- Media
- 3
- Resources
- 1
- Solutions
- 3
- Ft Worth,TX
- 85 CJ7, 258,4.0 head, T177, D300, Dana 30, AMC 20, 3.54
Had the front end aligned.
I knew the caster would be off I am using OME 2.5" lift springs.
Angle is 3.8* and 3.6*.
Can find 2* shims and 4* shims. No 3* shims.
The 2* would put the angle at the bottom end of the spec (5*), the 4* would put the angle at a little over the top end (7*)
This assumes that the shims actually add the advertised angle increase. Have read here and there that the shims give less angle than advertised.
Any opinions on which to go with?
. You may well need new axle U-bolts, and spring center bolt.
