- Media
- 1
- california
- 1965 CJ-5 Buick V6 Ford T-18 4-Speed Spicer 20/18,Warn Overdrive Dana 30 & 44 w/Powr-Lok posi / both,4.27 gears 33" tires.
I'm not sure as Sasquach mentioned about a ground plane versus a non ground plane antenna...........I only knew of one choice. Might be there is now some difference.
The ground plane theory is about what you have around your antenna to enhance it. Base Station antenna's with there tall vertical mast & horizontal legs are ground plane antennas at there very best.
4 foot is fine as long as the tip is a few inches higher than the roof..........and the 18' of cable I will correct myself is actually a 1/2 wave as my old memory now tells me that 36' is a full wave length at 11 meters. In either case wrap up the excess in the rear no kinks and you will be fine.
