- Media
- 1
- california
- 1965 CJ-5 Buick V6 Ford T-18 4-Speed Spicer 20/18,Warn Overdrive Dana 30 & 44 w/Powr-Lok posi / both,4.27 gears 33" tires.
PA,
There are some folks that say it perhaps is not needed, the antenna manufactures are the ones that dictate what length coax is required.........the length boils down to the ability to tune the radio / antenna based on the wave length at 11 meters / cb band. One wave length at 11 meters is 36 ft. We all know that 36 ft is out of the question so manufactures wrap and load the antenna electrically to make up that tunable distance.
A little extra cable has never been an issue except for people thinking of reasons they cannot store it. Coax is covered and wrapped with a ground surrounding the cable & unless your standing on it or driving over the cable its pretty bullet proof.
12 volts direct current is not an issue around coax unless your making a bundle of it tightly wrapped and mixed together. Lets face it I would hope that were all smarter than that!
High frequency radiation like ignitions and alternating AC power is a problem to radio waves. Good grounds and good clean connections to a reliable 12v source is a must.
IE: don't tap into your heaters 12v wire or you may get a hissing noise in your radio when the fan is on.
8" in +circle is fine no kinks.
