Chain Projects
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
Have you ever had a jeep project you simply couldn't move forward on due to how many other projects it would kick off? Most of you are heading into your off season, sure there will be a short but intense flurry of jeep activity focused around hunting season, maybe some snow plowing after that, but for most of you there is a down season. Unfortunately or fortunately here in he desert SW using the jeep is a 12 month proposition. Essentially there is no long period of time where the jeep will be out of service. Therefore my problem. Several jeep projects are in the kick off stage but to do one would require doing the others as well. Most of these chain projects are focused on removing, repairing and rebuilding PO attempts to improve his jeep. Then to rebuild things to meet my needs. At this point most everything is "fixed" except for the back of the jeep. Project examples"
PROJECT - Remove and replace the 15 gallon gas tank with the 21 gallon tank I have in the garage along with the necessary hoses and filters. Have you bought hoses lately? OMG get out the check book. ...... An easy enough job if the jeep were un touched. Unfortunately the PO replaced the rear bumper/frame cross member with a bumper about 1/2 what it should be. Besides that he built it evidently without a drill or metal saw. Everything I welded in place and cut poorly with a cutting torch leaving flanges over hanging the tank bolt tabs. To get to those tabs it will be necessary to cut the flanges, to cut the flanges means I need to remove the bumper. Since the bumper is welded in place the thing will need to be cut apart and removed. Since the rear bumper replaced the rear frame cross member which does several things, it holds the gas tank tabs, the body mount tabs, at the very least the cross member has to be installed. The cross member is sitting there waiting in the garage right now.
PROJECT - It has always been in the plans to remove the bumper and build a new one. So, parts have been collected for the job, but not all the parts. The raw steel hasn't been purchased yet. And various plans have been circling in my mind for almost a year now. This bumper will be far more that a simple metal piece. Oh no it will have, a receiver hitch, two recovery points, tail lights, and one of those great strong tapered bearing hinges for the tire rack. Then there is the possibility of adding a rear end winch.
PROJECT - If the bumper is removed a major rebuild of the tire carrier will be necessary. I'll use the tire carrier part with the original hinge removed and welded to the bearing hinge installed in the bumper. Oh yeah the tire carrier will have place for a gas and water cans.
PROJECT - Once the fuel tank is removed, for some unknown reason the PO welded two 1"x10"x the inner width of the frame, pieces of steel to the frame just in front of the fuel tank. Since the potential bomb the fuel tank is removed this is the perfect time get rid of those darned steel plates. They must weigh 100 pounds or more and they are in the location I want to place my OBAir pressure tank. To get to the plates it would be much easier to remove the rear axle.
PROJECT - Since the rear axle is removed this is the perfect time to put those 3.31 gears in. That's a whole new and interesting thing in itself. If the rear axles have the 3.31 gears this is the time to install the front axle I've already installed the gears in. But the front axle is a disk set-up I'll need to install a new master cylinder and a proportioning valve.
PROJECT - while at it the seal for the front drive shaft has been leaking lately. I've got the seal, I might as well replace that.
Yeah see what I mean by Chain Projects? One apple picked from the bottom of the pile and the whole thing comes down at once.
Do you have a similar list? Think about it, I bet most of you do.
