Chevy 350 fuel line
Chevy 350 fuel line
The three port Chevy fuel pump was used on older model 350's to ensure that a constant supply of fuel went to the carb. :) During idle less fuel is needed. During full throttle all the fuel you can get was needed. :drool: So the fuel pump actually pumps more fuel than is needed all the time. Thus the reason for the third port - a return line. ;) This kept the pump from pushing to much fuel / pressure to the carb while at idle. You can replace this with a 2 port fuel pump (NAPA should have the correct interchange numbers), and eliminate the return line at the pump. :) I doubt that you'll ever get the 350 cranked up enough to starve it of fuel in a Jeep. Now if your building a rock bouncer? :eek: That's a different story.[/QUOTE
thanks alot peanut butter, I did go with the two port from napa !
Pretty much ALL, FPs flow at a higher rate(GPM)than what is needed.
3 weeks, 6 days, 22 hours, 27 minutes, 22 seconds
