cj-7 flat dash in a yj
kelgorreeks
new jersey
94 wrangler stock drive train
ok here goes i have a CJ7 dash complete and wanna put it in my 94 wrangler has any one done this or have any advice please help i hate the yj plastic dash junk .
the tubs are pretty much the same, once you remove all of the plastic. You may be down for a few days, depending on how much time you have to work on it. Also may need the brackets for the steering wheel, as I don't know if they will transfer over. Do you have all the gauges? Also will have to look at the wiring connectors. If you have the time, I think that would be a great swap.
i have all the parts just trying to see if anyone has done this i know it can be done just wanna see what to look out for learn from someone elses attepts:):):D
What about your guages? Unles your Yj is a 91 or older you will need to buy the expensive <-BAD WORD-> electric Cj style speedo....
Just saw you said you have a 94 so obviously you will need the electric speedometer since you will not have a cable drive in yours
