cj and yj springs
They are indeed flatter.They are flat though? no arch?
YJ springs they have a larger bushing and use a sleeve. What you want to do is buy or fabricate shackle hangers to match, big improvement over the CJ bushing. I made mine as well as the shackles so that I could build exactly the length I wanted, cutting torch, grinder, drill press and some plate steel.
I did see and will look for it but someone is selling a YJ hanger as a kit that would save alot of cutting work.
You dont have to do anything to the rear....
And the front only needs the front shackle hangers addressed. The rear hangers on the front accept a 2½" spring just fine, they are the same spread as the front hanger for the rear springs.
There are many companies out there that make a front shackle hanger for converting to YJ springs.
Why mess with something that is already there...and perfectly useableCorrect you don't "have to" but why not? other than cost anyway.
Here you go.I still want to see the Demented width
The only thing that needs to be changed to add YJ springs is the front shackle hanger on the frame horns. Everything behind that is already set up to accept the 2½" YJ springpacks.
Here you go.
ah, I was referring to the use of demention, should should have been caught by the spell checker. I think you meant dimensions, which are a measurement, not dimension which is a property such as one dimensional.Here you go.
