CJ manual brakes upgrade to YJ power
Hammerhead
- Media
- 5
- Ontario, Canada
- 85 CJ, 95 F350 , 1993 Bronco, 01 Valkyrie, 2 sleds
Easy upgrade to power brakes. My CJ is a 1985 with manual brakes. The doner vehicle is 1992 YJ. All you need is the booster, rear bracket and both the primary and secondary push rods. Got the parts free. Took less than an hour even while having a beer and socializing with some pals.
I left the brake lines in my master cylinder and disconect the brake pedal from the push rod. Unbolt the two master cylinder bolts and pull the master cylinder away from the firewall stretching the brake line coils out. Remove the snap ring from the back to pull the push rod out. A bit of brake fluid came out. remove the small snap ring from the push rod and the push rod can be pulled from the spacer. Put the spacer and snap ring back into the master. After making measurments of the original push rod and the secondary push rod from the booster I found the YJ secondary push rod to be about .04" shorter. Lucky thing is the YJ's is adjustable. Unscrew it one turn and it is about right. The primary push rod (brake pedal to booster) was about .220" too short. No big deal, I put it in like it was. Turned the primary push rod around 180 degrees and put it in the jeep. Bolt to firewall, no drilling. just remove the four bolts that are meant for power and use them. Connect the brake pedal. The master cylinder bolt holes are a bit tight to mount to the YJ booster. You may want to elongate them or you could do what I did. Use the impact gun and force fit the basterd. Get your friend in the jeep and have him/her push the brake pedal down very slowly while you watch in the master cylinder for air bubbles. (recall that fluid had leaked out the back when the original push rod was being removed.) Have them release the pedal just as slow. Repeat a few more times. I only had a few bubbles the first push and release then no more came out. Run the vacume line to the intake manifold. I put mine into a 3/8" port found under the carburator in the carb spacer. Your brake lights are on because the new primary push rod is almost a 1/4" shorter. Just bend (by hand) the brake light trigger switch tab at the top of the brake pedal. Turn the key, get going and stop. Wee, that was cool. Good luck.
