CJ, TJ, or Hybrid?
coldwater
Crazy Sr. Respected Jeeper
I'd like to build it as close to stock as possible, yes. Really the only major mod (besides the diesel) is an flatbed/applecrate. I like parts that are perhaps stronger than stock, while not modifying too much, if at all. That's why I sometimes think that the old fashioned, simple leafspring setup is better-just Ubolts to the axle housing and no control arms etc. to worry about.
I stripped my old 1980 CJ7 to the frame, rewired it headlight to taillight with a Painless Wiring kit, and put in an 85 I-6 engine by myself. I put in headers and intake manifold from Clifford, a Cagle pressure controller, and a a Weber 32/36 carburetor, and the Jeep had lots of power. My only beef was that even when it was eight years old (I bought it in 1988) it was a rust bucket. By contrast, my TJ is 13 years old and the body has no rust at all. I originally intended to rebuild that CJ, but sold it to a cowboy who still uses it to ride the fence!
As far as the diesel, I get confused myself. I've heard it's a good idea, doable, and also that it's an absolute nightmare. I've heard that the I-6 engine can be turned into a diesel, but then how much would that cost, and will it be a major pain to fix if it breaks? I've heard a small diesel swap would be no big deal, and also that it would be a huge, exorbadently expensive underrtaking. I've heard diesels are easier to fix than gas, and visa versa. It's somewhat confusing, and frustrating. I figure if the diesel becomes out of the question I'll stick with a straight six.
This site is great because I get to hear all sorts of viewpoints. Thanks!![]()
Well, this is my bottom line, and what my personal choices were when I did my last frame off. "I" wanter a largely stock Jeep. One I could easily work on, one that used Jeep parts as a whole so that everything was a bolt on, and didn't need a notebook of what parts I used from other vehicles when something went south on me. I stripped my 7 to the bone and used a narrow 44 in back from an old 5, a disc brake narrow 30 front, both were stripped out and completely rebuilt end to end, and used lockers. I used a soft ride 2.5" lift, a AMC 258 i6 / 4.2l -6 engine, a Dana 300 TC with a T-176 tranny. Twin sticked the 300, and rebuilt both units. A centech wiring harness, and every single part on the Jeep was eather rebuilt or replaced. I used a 4WD Hdw glass body, fenders, and windshield frame. The day I finished the build, I pulled it out of the garage, and in going on 13 years, has never once broken down on me. Not once. It generally goes where I want it to, but I don't beat it in mud and try to crush mountains with it. It is one of the most reliable and capable vehicles I have ever owned. And It is just a CJ7 , nothing more. You need to decide just how big and bad you need to go to achieve your goals. In my personal opinion and experience, when used properly, the Jeep was pretty well designed out of the gate, and all I have ever needed. And I have packed away some pretty good adventures in that little 7 over the years. A Jeep is a 4 wheel drive opinion, and every owner will have their own idea of what they think is the "best" way to build. I personally prefer a largely stock unit with a few upgraded parts to help bring out It's best.
edit:...... Opinions other than mine are not valid, and should be ignored. You can do so politely, but should still be ignored.
