I have a (Pro comp) rock crawler hitch bumper rated for 2500lbs. The highest legal for the CJ7 is 3500 (class 3). Those prob require drilling and bolt to the frame. Not difficult to install but I think the larger one will affect clearance a little. Prob $150 for a hitch. My bumper was $140 or less and has d rings.
You can add a weight distribution and anti sway control to help it stabilize and you would not feel much of that 1800lbs. There is a company that makes a combo that runs $3-400 if I recall, but it is worth the safety. It actually increases the amount you can safely carry as it pushes the weight off the bumper and further back on the tongue. I would definitely consider the WD and anti sway.
I don't think you will find that light of a pop up with electric brakes or you could install a brake controller as well to reduce the trailer from pushing you when you stop. You may be able to add, but not sure how cost effective.
One last thing, if you have an auto trans and don't have a transmission cooler (I don't think CJ's have but mine is manual) I woud install (especially if you are up and down hills). They run about $60 or less and are easy to do. They go right in front of the radiator.
I ran the largest UHaul hitch center in Phoenix for a while. You would not believe how many Honda cars get hitches and tranny coolers installed and move smaller but loaded trailers across country.
