CJ Wiring Question
Rescue Diver
Full Time Jeeper
- Kansas City
- 1979 CJ-7 with a fiberglass body and 1982 wide track axles, 258 I-6 with a 1995 4.0 head, HEI distributor, Motorcraft 2100 Carb, T-18 wide ratio tranny, Super Lift Springs and 33s, a 1997 BMW 328i, and a 2010 REDLINE CONQUEST TEAM Cyclocross Bike. :)
I got a 83 the wiper wires pass up under the cowl seal.There's a slotted hole where they go threw below the motor.Feed them up threw the hole behind the dash.You'll have to have the window down to see the hole then strait to the motor.
So the flat red/yellow/green wiper motor wire ribon goes under the cowel seal and through a hole that's directly under the motor through the cowel?
I'd almost rather drill a hole in the dash behind the dash pad to run them through so it doesn't interfere with the seal. Being a fiberglass tub, the cowel is pretty weak and sags without the dash bolted up to hold it straight. I'm doing everything I can to try and make a good seal so I don't have leaks. If it does still leak in the rain, I might just silicone the seal to the cowel and just live without being able to put the windshield down. That will be a last resort because I really like that feature when just going slow through the woods or at the drive in.
