The
CJ5 is the only CJ built under 3 Jeep owners, Willys introduced it in 1955 and a month later merged with Kaiser. They continued to use the Willys name for some time but eventually took the Willys stampings off the Jeep, replacing them with Jeep stampings. Jeep was sold to AMC in the early months of 1970.
The
CJ5 was the longest running of the CJ family, it was produced in 3 generations, the First was this, the "short nosed
CJ5, so named because the next generation they added close too 4 inches to the Jeep, all in the engine department.
The
CJ5 was developed from the Military model, the M38a1, following the military model by 2 years to go into production. It seems it took this long to convince the military to allow Willy's to use the platform the Military had paid to develop. It is very closely related to the M38a1, with very few changes. Features like fuel tank size, low range ratio are a few of the changes. Willys even took a few years to delete some items like the cut out for a snorkel in the hood die. However they did use a one piece window for this Jeep ( a 2 piece window was an option at first).
The frame size and pattern of tabs are extremely close to all earlier jeeps.
Being the first of the non flat fender Jeeps of the CL line it broke ground in the "Streamline" range, if a Jeep could actually be so.
It was introduced with a Dana 25 closed knuckle front axle, a
Dana 44 tapered 2 piece semi floating rear axle, the D18 transfer case was geared at 2.43 to 1. the original transmission was the T 90 3 speed, they used this transmission behind the 4 cylinder engine through 1971. The original engine was the 75 hp F head 134 from the
CJ3b.
Softer seat, and softer springs were things Jeep told the public made this a better jeep than other models
The
CJ5 specs are as follows:
Wheelbase, 81 inches
Length 135.56 inches
Height 67 inches
Width 71,75 inches
Tread 48.44 inches
Front overhang 22.56 inches
Rear overhang 32 inches
Front/rear axle clearance 8.62/8 inches
Approach angle 45 degrees
Departure angle 30 degrees
Break over angle 30 degrees
Tires were 6.00x16
Curb weight of 2274 pounds (in the F134/T90 form with no options)
GVW of 3750 pounds
Axle ratio, 538. to 1 (Base model)
D 18 transfer case with a 1 to 1 high range and a 2.43 to 1 low range
T 90 a gear ratios (1953 to 1962) 1st 2.79, 2nd 1.55, 3rd 1, reverse 3.79
T 90 c gear ratios (1963 to 1971) 1st 3.34, 2nd 1.84, 3rd 1, reverse 4.53
T 86 aa gear ratios (1965 to 1967) 1st 2.79, 2nd 1.68, 3rd 1, reverse 3. 79
T 14 gear ratios (1967 to 1971) 1st 3.10, 2nd 1.61, third 1, revers 3.10
T 98 gear ratios (option behind the F134) 1st 6.40, 2nd 3.09, 3rd 1.69, 4th 1, reverse 7.82
T 18 gear ratios (option behind the V6) 1st 6.32 2nd 3.09 3rd 1.69 4th 1. reverse 7.44
134 F head (1955 to 1971) 75 hp at 4000 rpm, 114 pounds of torque at 2000 rpm
2 heads were offered with this engine, a yellow painted one with 7.8 to 1 compression ratio for high altitude use and the standard engine had a black painted 7.4 to 1 compression head.
225 V6 (1965 to 1971) 155 hp at 4200 rpm, 235 pounds of torque at 2400 rpm
It is interesting to note that at the beginning of the production of the
CJ5 it was mainly a work vehicle. Sales were strong to agriculture and industry. By the time 1971 came around this vehicle had a strong sporting reputation and was a favorite among the off road and sportsman crowd. More and more units were being sold as secondary vehicles to be used in the back country while exploring or while fishing and hunting. The utility vehicle was morphing into the Sports Utility vehicle and more Brands were entering the market for their share.
The
CJ5 was a nice competition to it's contemporaries.
The Warn overdrive was an option giving you 25% more gear ratio in any gear, and a PTO was offered that came directly off the transfer case and operate a winch or a large selection of farm implements. Several fire fighting implements could be bought to match the PTO as well as construction tools, this was a very versatile vehicle.
