CJ5 360 swap?
CJ5 360 swap?
ray299
Somers CT
I have a 1985 CJ5 that had a AMC 258 i6 / 4.2l but I have an AMC 360 that needs to go in. Can anyone tell me what motor mounts to buy? I heard I needed different ones than the AMC 258 i6 / 4.2l ... also, is that all I need to bolt it up?
I don't have time for trial and error or making my own as I have done in the past.
Thanks in advance!
Thanks in advance!
You need AMC V8 motor mounts for a CJ and not the mounts from your donor vehicle.
You also get M.O.R.E bombproof.
Your also going to need to rearrange a little fuel line and extend some wiring here and there. What Transmission are you using behind the 360? The T-176 is the best Transmission of that era but depending on whats been done to the 360 even that Transmission is borderline behind it.
