Cj5 Hybrid?
Cj5 Hybrid?
Bassic1967
Newark, Ohio
1978 CJ5
I am thinking about building a CJ5 with a TJ suspension, Throttle Down Kustoms builds a hybrid frame, but only shows CJ7 and CJ8 available. does anyone know if the TJ suspension will fit under a CJ5 ? or is the wheelbase too short?:confused:
The wheelbase of the tub is short but if your just putting a tub on a frame you could always set the tub back a little bit on the frame and then trim the rear wheel wells a little bit. Anything is possible if you are willing to put enough work in.
