Brakes 1975 Cj5 E-Brake Removal From Backing Plate Tips
curly
Arkansas
1975 CJ5 258
Hit it with PB Blaster or Kroil and let it soak in for a while then try again. If that doesn't work go to heat. If that doesn't work go brute force till it breaks. Cut only as a last resort, and then use something tiny, like a Dremel with little cutoff wheel.
For the underbody I have a powerful pressure washer, but it has a big wand which made is almost useless for getting under the Jeep in the driveway. I found this on the Bezos-Chinese-Emporium.
Nice short handle, so I can use the creeper to get low on the side (or all the way under) and blast the whole underbody (you may want to put the plugs in the drains if your tub is nice because dirt will shoot out of them and get everywhere). Blast everything (you're not going to hurt anything), hit everything with a spray bottle of degreaser, let it soak in and do it's thing, and then blast again. Wear some sealed safety glasses though, and unless you want to get filthy it's best to go full Walter White with a Tyvek coverall and hood. I certainly don't do it all the time, but if I know I'm going to be working under the car soon I give it this deep clean. Makes for a nicer work environment.
2 people working together makes getting that ebrake cable off easier. Even then it’s fun
For the heat, I'm assuming I can try to use one of these hand butane torches. Do I need to be concerned with heat around the backing plate?
I'll try to clean out from under, but will need to borrow a pressure washer from a buddy then. Probably an obvious question, but do I need to be worried about spraying over or around the Transmission ?
I will give that a shot, definitely would help having an extra set of hands as you can imagine with the vise grips. I'll see if adding a little heat doesn't work, but if not, I'll be conscripting some help!
On Propane or ANY Torch work.
A "Smart Trail Driver" will have
a Fire Extinguisher ready.
Then get yourself some really watered up Rags Handy.
Works for those little grease/oil flare ups,.... putting yourself out if HOT Dripping greasy oil starts your pants or shirt alight.......
and if course to Quick Soak your hand ! DAMN I didn't think it was That Hot !!
My Nickel.95
From 68 years of Stacked up
Disappointments......
As long as the fittings are all screwed in there is nothing on the underbody that isn't designed to withstand water. Your Transmission and differential are completely sealed and in cast bodies. The only thing I wouldn't linger on are old rubber hoses (new ones are fine), but just passing over them won't hurt them.
Contact points look good. As long as there is no loose dirt of rust it's good. :)
Great to know. I was beginning to think I was doing a fools errand.
I’m going to try to finish my brake job tomorrow (or at least got my rear axle wheels with new shoes). I’ve been slow moving on this project, but will keep yall updated. Thank yall for the help!
The "Nail Pin" connector for the shoe retainer isis Upside Down !!
The Cup recesses into the Spring.
I use a Needle Nose Vice Grip to put those back on.
Not dumb... Funny thing is that drum brakes are supposed to be simple but are much more difficult than disc brakes. Oh so many parts... :chug:
Drum brakes have not been fun! But at least I'm learning things! The many parts is real lol. I thought I had all the hardware I needed, but turns out I needed to order a self adjuster kit! Now here's hoping I don't need to replace any of my parking brake strut springs which for some reason aren't on rockauto, and I don't want to pay 30+ to get a full set elsewhere. Extra parts should come in a few days.
Don't feel like the "Lone Ranger".
Brakes Jobs are like going to the Dentist!
Nobody Likes It.
And they are "Frustrating Fun" for everyone.
And Now you Know how it All Works as a unit. Knowledge has No Price.
Drum brakes are easy, but I was doing my own brakes before discs were an option.
Best of luck.
knowledge is something you get to keep for life, no payments!
That looks correct. Kinda.
The end at the top usually goes down like the spring on the left.
That washer with tabs on the post at the top, I don't think it's fully on, prohibiting the spring hook from having space.
But if it doesn't pop off it is probably fine.
Special pliers are sold for the springs and clips.
It's been ages, I have been using a brake shop for my cars for several years.
