cj7 brakes
paparooster
- Graham Wa.
- Rig: '74 CJ5
Motor: AMC 360 V8 Holley 670 Truck Avenger carb
Trans: NP435
Transfer: Dana 300 Twin Stick
Front axle: Dana 44 w/ Detroit Locker, Chromolly Axles, 4.88
Rear axle: High Pinion Dana 44, 4.88, Detroit Locker, Disc Brakes
Suspension: Blazer Springs.Others:Warn Winch, Via-Air onboard air, Red Dot rear heater, H.E.I Distributor, Dual Electric Fans, Custom front & rear drive lines, Toyo Tires 15 x 35 x 13.5, Painless 70 amp fuse buss, 140 amp alternator
1978 cj7 304 turbo 400 Quadra-trac transfer
Hi to all jeep lovers . I'm working on a 1978 CJ7 for my wife . My problem is with air in the brake system . I have replaced everything with the brakes except the hard lines .Yes i have bench bled m/c then started bleeding at farthest point to closest point of mc when completed . I also have a power bleeder also but still air in system .. I have researched and found out that there is a 2 bolt caliper or a 6 bolt caliper . local parts store ask if 10" or 11" drums .. so what is this 2 bolt or 6 bolt cailper
