Build Thread CJ7 let the fun begin.
gootee08
Dayton, Oh
cj7, 4.2L I6, T-5, Dana 300, bone stock
Thanks for the compliment. I like the bumper design you picked , thats one of my favorites. Slightly better than what you have now. :D Do you have a bead roller? Like the way the panel you made blends right in.
As far as axles the only thing Id do is throw a set of one piece axles in the rear. Maybe add a lock rite or aussie locker. That will do you fine while your on 33s. I wouldnt spend any more on them after that. In the mean time grab a set you can build to handle your eventual 37s. That'll minimize your downtime when you do swap.
Along that same line your inline 6 will be fine with a few mods. The Dana 300 Transfer Case is also a solid unit. The T-5 Transmission is usually considered scrap by most off road enthusiasts. It wont hurt to replace the synchro and give it a good once over but Id treat it just like the axles. Probably fine with the 33s depending on its condition , but a time bomb for larger tires.
Share as much as you want. Theres always someone looking for some ideas on here. Im sure your 3/8 rod idea will be used by another Jeeper out there. I dont do alot of sheetmetal work considering I dont weld but one day...
As far as transmissions probably the 2 most popular manual Transmission are both 4 spd. The Jeep/Ford T-18 and the SM420. Both have excellent reputations for durability and are popular for rock crawling due to their low 1st gears.
I can speak for the T-18 and let others chime in on 5 spds and the SM420. The good thing about a T-18 is the were offered in Jeeps from the factory. You can usually find a T-18 for around $650. First gear is 6.32 and the rest are basically the same as a T-150 3spd. They can be modified to accept the Dana 300 but were originally backed by a Dana 20 Transfer Case . Here is a great site for popular Transmission /engine/Transfer Case swaps
Novak Jeep Conversions - Home
A 44/60 set sounds good for what you want in the end and $400 is a good price.
There are a bunch of mods out there for the I6. I think the one your talking about is the Team Rush upgrade. Heres a good link for that.
Team Rush Mod (Writeup w/ Pics} - JeepForum.com
I did this along with a Mc2100 swap and was very happy. Unfortunately I did both at the same time so I cant really tell you just about 1. Together it was a great bang for the buck cure for my CJ7 .
That said on the Scrambler I went with an h.e.i. I could open up the plug gap to .50 and it really smoothed out the idle. Power gain was instant in my case, just due to it smoothing out and getting rid of flat spots I had throughout the powerband. When I do my new motor I will go this route again. You get to get rid of more wiring and that ignition module as well.
I like the idea of the 4.0 head swap as well. Heres a short write up on that.
http://www.jeep-cj.com/forums/f2/258-4-0-head-swap-results-8500/?highlight=head+swap
Now theres a bunch of different intakes and headers you can use, but you have to be careful or you'll end up with a bunch of mis matched parts that dont work with each other. Some intakes take a Holley 4 bbl pattern. Some wont work with a header. Some just plain dont work... you get my meaning.
If you werent looking at such large tires Id tell you to do what I did. Buy a parts Jeep and rebuild the driveline of it to your satisfaction. In your case your still going to need something other than the stock axles. I bought my rusted out junker for $450. After I get some frame repair done I can drive the CJ7 while having another driveline being built the way I want. A best of both worlds thing so I hope. ;) I dont plan on going any larger than a 35 in tire and will probably stay at 33s.
Anyway those links should be some good reads for you. Enjoy and get a good game plan together. It looks like with your skill you can be driving that Jeep around on 33s while builing the stuff you need.:cool:
Thanks Pete,
I don't have a bead roller yet but working on biulding one. I just used a 3/8 rod and t dolly, then beat on it with a big hammer. It did not look like there was a lot of interest on sheet metal work here but I can post picts of what i make if there is.
Lmao being how about 75% of cjs are swiss cheese, help and hints on sheetmetal work is always welcome, seems though that fixing rust isn't most peoples main concern versus just gettin a jeep running or keeping it running right.
As for transmissions id look into the ax15 if you want a 5 speed, its probably about the easiest to swap in, and rather strong for a medium duty tranny.
Droooiiddd 2
Hey were in the same city. I also been all over Alaska. Drove the alcan highway and drove the dalton.
Droooiiddd 2
Thanks, I was just informed by my wife that I will NEED to do some more welding on the jeep. Darn I'll have to spend some time in the shop:D. I just order some panels, so should have some sheet metal pics soon.
I'll look into the ax15, thanks for the input.
We are planning an RV trip up the alcan next year, and dragging the jeep up to be our Alaska vehicle.
The panels came in from JC Whitney in just a couple of days. In the ad it said "some fitment needed", it should of said "remake as needed".
Thats about the same way Id describe the ones from Quadratec. Your also spot on about removing excess material in small amounts. Thats why you'll see alot of people recomend these guys: http://classicent.com/jeep.php Lookin good. :chug:
Hey I like the sheetmetal work you have done. In fact your a few steps ahead of me. As far as your sheetmetal, what thickness is it? Where are you getting your metal from? I use metal for industrial duct work. It's called paint grip. It's 0.033 thick as opposed to body sheetmetal 0.032. Thats some really nice work your doing too! I gotta make on of those dolly things.
That is some good work! I'm about to tackle the floor pan on the driver side myself, so this is good info! Can I ask what kind of winch you have? I have a friend that I'm trying to talk out of him, a 12,000lb Ramsey with the worm drive motor set up. He keeps trying to tell me it too wide, but he hasn't measured it for me yet! LOL, we keep going back and forth about it, but I think it'll be mine soon!
Ps, rr41mag the t dolly is just some 1/2 inch round bar I cut and welded together. Ground a dome on one end and left the other flat. It has turned out to be rather useful.
Greg
You have way more patience than I do. :) Looks good , keep the pics coming.
If you plan to eventually run 37" tires and want a 5 speed, I'd go with the NV4500 5speed. It was originally found in Chevy 1/2 & 3/4 ton trucks. They have a decent granny first, and the beauty of the over drive as well. You get to have your cake and eat it too lol, use the granny gear for crawling around off road, and the overdive for blasting down the highway to get there!
In short it's a 5 speed that will handle pretty much whatever you throw at it. Plus with it being in a GM product you can find them around for decent prices, and if you did manage to ruin or wear part of it out you can find replacement parts at reasonable prices too. Just a thought.
On the AMC 258 i6 / 4.2l 's I've had I get a GM HEI dist. out of a Chevy I6 and put the Jeep gear on the shaft, and drop them in. Then I run a Motorcraft 2 barrel carb from a Ford v6. The Motorcraft carbs work exceptionally well off road and run by far the smoother than any Carter style 2 barrel I've ever had.
If you do the conversion dist yourself from the boneyard the cost is mere pennies compared to the DUI kits and what not on-line.
On the 258's I've had I get a GM HEI dist. out of a Chevy I6 and put the Jeep gear on the shaft, and drop them in. Then I run a Motorcraft 2 barrel carb from a Ford v6. The Motorcraft carbs work exceptionally well off road and run by far the smoother than any Carter style 2 barrel I've ever had.
Man...that's some good info...what year for the chevy i6 and the motorcraft 2 bl ford v6?
If memory serves me correctly it was around 82-83 for the I6's. And as far as the Motorcraft 2 barrel, I usually get a re-man one from the parts store, I order them for a Ford Fairmont with the V-6. They run about $110 my cost and I have them in about 2 days from my local Advance Auto.
When I do these conversions for customers with CJ's or earlier YJ's they can't believe how smooth and powerful their Jeeps are now. It truly makes them run very well, one guy swore I changed his engine, he said "there is NO WAY a six banger with 180,000 miles on it can run THAT good" lol.
