CJ7 Seat Belt Options
dwyant30
Central Point, OR
86 CJ7 with 258ci NP435 Dana 300 Dana 30 Front Dana 44 Rear Howell TBI Sitting on 33s.
Has anyone tried these in a CJ?
I'm wondering how they would mount into my CJ7 .
I just put a set of thoes in my heep. I haven't driven it much but I can tell the 4 point harness is going to be a PITA. I see a camlock replacing them pretty soon.
You need to have seats with the slots for the belts to use a harness like that.
they need to be mounted with top straps slightly lower than shoulders at a 45 degree angle to prevent back and neck injury in any kind of accident , and lap belt should also be placed at a 45 degree angle ,you can disregard the center strap mounting angle since you have a 4 pt harness
you ask back and neck injury ? It could and would occur if top straps are mounted anywhere lower beyond the 45* mark will have a downward pull on shoulders causing injury to back and neck
I do encourage you to do your homework on the belt your going with
I didn't think there was so much to know till I read this:
Pirate4x4.com - The largest off roading website in the world.
I just removed the 5-pt and went back to a typical 3pt retractable. These harnesses do exactly as designed and your movement is Limited to nothing. The lack of movement created by a 4-pt and 5-pt harness is a pita when you are wheeling and need to look around (obstacles, line selection, tire placement)
In competition, you have a spotter so you dont need to have the mobility to see anything :rolleyes:
For casual wheeling, trail riding, etc....they are a hinderance.
But safety is safety. If you feel you need them, by all means, go for it.
I was discussing some ideas on seat belt changes with my wife. We have an indirect connection to a teenager who died in a CJ while wearing a 4 or 5 point harness and was hit by a drunk driver on the street. From what I know, he died of organ damage due to the harness -- so I suspect he may not have had them mounted high in the back, behind the shoulders (as mentioned above).
My wife asked about the liability of changing seat belt mounting points. If I sold the Jeep and had changed the mounting or installed seat belts incorrectly, would there be liability if a future owner was hurt or killed? I would think there might be. Has anyone heard of something like this happening with seat belts or other mods? She thought it would be wise to have these kinds of changes professionally done, partly to share any potential liability.
Interior Seat Covers
