Build Thread Cj8 build from parts
BIGTRUCKNUT
- Northern Virginia
- '45 Ford GPW; '73 CJ5 350/NP435/D20; CJ8 304/T19/doubler/D300; '88 Ramcharger 360/NP435/NP205/D60s; '04 Ford Excursion PSD; '00 WJ w/3 and 4-link, D50/Sterling 10.5" axles
Started building a CJ8 Scrambler this month (May 2013) from a pair of old, rotted out CJs given to me by a friend. Already have a CJ5 that I drive daily and wanted to build a "first Jeep" for my youngest daughter since her two older siblings have Jeeps too (XJ and WJ). Basically, only useable parts off the two donor CJs are the drivetrains (AMC 258 i6 / 4.2l and AMC 304 w/T150s/D20s/D30s/AMC 20s) and some accessories/small parts. Frames and bodies are rotted beyond repair which led me to decide on a CJ8 since I was essentially starting from scratch anyway. All drivetrain components will be rebuilt before installation.
Ordered (and recieved last week) a TDK CJ8 frame configured for front reverse shackle using YJ springs and longer XJ springs in the rear. Expect to order a new steel body in the next few weeks. This CJ8 is going to be a dual purpose vehicle - daily driver and multi-purpose off-road vehicle that will need to be equally capable on the beaches of the Outer Banks, running through the mud, or out on a group trail ride with my daughter behind the wheel. Not building to "stock" necessarily, will upgrade parts/components as I go along. My general build plan:
-TDK CJ8 frame (stock wheelbase, front reverse shackle YJ/rear XJ springs)
-Steel body (basically unmolested)
-Tube front fenders
-AMC 304 /T-150 /Dana 20 engine, Transmission , Transfer Case (for now however, toying with 6.2L diesel/SM465 idea for later install)
-Dana 30 /AMC20 axles with upgrades for strength and traction
-35" tires
-Full cage
-Steel doors, soft top
Pretty agressive build; Trying to complete and have on the road by Labor Day 2013 (4 months build time!!!) Not my first ground up (but certainly the most ambitious), I have over 35 years of wrenching experience, and I'm not afraid to dig into any component. All work to be done by me with occasional help by family/friends as necessary. Wish me luck and check back in on the build to keep me motivated. Will post initial pictures within the next day or so and further posts/pictures as things get done.
Semper Fidelis,
Ty
-Tube front fenders
-35" tires
-Full cage
Semper Fidelis,
Ty
