clutch adjustment or stuck plate??? need help
79cj7bogger
nebraska
79 cj with a 258 mated to t150
Have T-150 tranny shifts fine in all gears when enginr off or with engine on and tcase in nuetral but when tcase is in 2 hi and engine running grinds when trying to put it in reverse and 1-3 doesn't go in at all..any advice?
How much free play at the top of your pedal do you have?
I agree with mtnwhlr. It sounds like your clutch is just dragging. Let us know how much free play you have in the clutch pedal before it starts to disengage and we'll know if we are on the right track.
Not much now re adjusted cuz i had no results did have bout an inch before it had pressure if it helps I just got it a while back been doing stuff to it in order to be driveableso idk how long it sat
