Clutch play HELP
jeremy5780
I have a 1985 CJ7 straight 6 AMC 258 i6 / 4.2l Bought a few months ago and slowly doing a little work. The clutch seems to work fine shifts smooth. but I noticed there was a lot of play in the pedal. It would go down 2-3 inches before getting hard then I noticed the clutch only engages in about the last 2-3 inches of the pedal before it hit's the floor or bottoms out. So I decided to get underneath and check it out, and this is what I found. I attached a video. If you could take a look and let me know what you think. I went through all the receipts the PO gave me and it looks like he put in a new center force clutch set, clutch disc, linkage kit and throwout bearing in 2004. Thanks
https://www.youtube.com/watch?v=iTkPHHXnq2I
