Coil Resister
dagr8tim
By the looks of the 77 AMC 232 i6 in my CJ, it has a resistor before the coil. I get 12.8 volts into it and 12 volts out of the resistor. I'm not getting any spark and I suspect it's a bad coil.
A friend gave me an Accel 140001 (ACCEL brand | Part #: 140001) coil that he had kicking around from a waggy project he sold. I'm wondering if I need to run the resistor with this accel coil, or if I can run it straight off the ignition wire.
Also, I got the coil used with no adapter on top. How can I rig it up to fit the fitting on the wire from the distributor to the coil?
Hopefully this solves my no spark issue and and I can move on to the carb.
