Contour Dual Fan
ThisGuyUKnow
Full Time Jeeper
- Featured
- 2
- Harleysville, PA
- 1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
On my way back from P-Cola today I stopped at the upull and sweat and bled over a ford contour dual fan... It was not easy to get out at all, that engine compartment is tight. I am surprised they can put them together.
Two bolts held it in and then it pulls out. sounds easy but the motors run along somesort of ac line that is hard to break off. I had to stand on the engine and pull with all my strength. A buddy would have made life easier but after test fitting the fan it was definitely worth it.
I have been running a Taurus fan which is a single two speed fan. I had to cut the shroud alot in order to clear the pully. I basically cut the shroud to the lowest point I could without interfering with the blades.
As you can see below, laying flat on the ground, the taurus fan is still taller despite the fact I basically cut it to the edge of the fan blades.
I cut the tabs that originally were used to mount the fan to the radiator mount so that the shroud could sit agains the fins. other wise there would have been about a 1/2'' gap between the shroud and the fins and the back of the motors would have been pushed further towards the belts.
The fan motors definitely don't stick out as far. plus I think the fact that they are not centered will land the water pump right between the motors
