Clutch Converting 76 CJ5 clutch to hydraulic
cglax6
Lifetime Supporter
Featured
VA
'76 CJ5, 351w, Ford T18/D20, D44 (open), D30 (open), 2.5" BDS spring lift, 31x10.5x15 tires
I'm having issues with the search function...not sure if it's my connection or what. I'm looking for some guidance on how to convert my clutch to hydraulic in my 76 CJ5 .
I'm sure I can fumble through piecing something together, but I'm looking to see if anyone else has done something similar and can point me in the right direction for installing a master cylinder.
I have power brakes, so I'm not sure if that whole system would be in the way of being able to install a master correctly.
Appreciate the help.
BTW, if you haven't been paying attention to my build thread, I just swapped in a 351w.
I have my old mechanical linkage for the AMC 304 , and could probably fab brackets to make it work properly, but I'm curious to see how simple/hard it would be to go hydraulic.
Mine is the original 4 banger setup, with a Novac made bracket which bolts to the bellhousing. The slave is a Luk reman for the GM iron duke 4. The master is original Girling made cylinder which Rockauto had a rebuld kit for. Luk also has a reman for the master # lmc 308. I'm not sure if it will clear the PB unit as mine is non power brakes. If need some measurements let me know.
Appreciate the help... measurements would be nice. Looking for length from firewall forward...and how long the pushrod is for the MC.
Sent from my Pixel 2 using Tapatalk
By your pics it looks like it would go under the the cable coming through the firewall. The master sticks out 4 1/2 " from the firewall and the rod which clipped into master is 4" center of mounting eye to firewall. It is over 1 1/2" from the top bolt of the PS unit bolt. My firewall had a stamped out circle plug where the master should mount. I don't see that in your pics probably not an option in 76.
Ok thanks. The hose up top is for the wiper fluid.
When you get a chance, can you take some inside and outside pics so I can see where it's mounted and where the pushrod connects.
Hydraulic wasn't an option on the 76s unfortunately, so no locator stamp.
Good pictures. Same as mine !
I'm sure a call to Novak could be worth while, hydraulic is the way to go IMHO. They are a good solution for an engine swap.
I went with Novak parts, not cheap, but they have it all.
I'll give those guys a call tomorrow. Seems like the way to go.
You can go online and find out a lot also before talking to them. What Transmission ?
You can go online and find out a lot also before talking to them. What transmission ?
Ford T-18 on a 351w. The slave and bracket piece are easy to figure out...just trying to nail down what I need to do for the master cylinder.
