creative brake system.
IOPort51
- Featured
- 5
- Media
- 458
- Garland Texas
- 1977 cj-5
2006 Toyota Tacoma
does anybody have any experience with putting a power booster on a manual brake master cylinder?? I would like to have a MC with the same size cylinder , front and back, and power boost. So the drum drum MC used in 1977 mounted on the power boost used that same year. Problem being the drum drum did not have the power option, as far an I can tell.
I know the flange is shaped differently but I think I could overcome that as long as the master cylinder was not going to blow a seal or the discs were not going to lock up with the slightest touch.
I may start by trying the drum drum, with the residuals removed, and see if that gives a positive result.:dunno:
