Cross member Parts
Cross member Parts
Tin Medic
Ft. Carson
85 CJ-7 Renegade:
Fuel Injected 4.2L I6/T5/D300
D30 with ARB Air Locker, AMC 20 w/Posi
Warn 8000 LB winch
VIAIR Onboard Air System
33x12.5x15 Goodyear MT/R's
Kenwood head Unit
Hella E-Code Lights
Does anyone carry the centering buttons for the front shackle end spring hanger? I need to replace the front cross member on a project CJ so I will need a replacement for the buttons also. Also, who carries the front cross member or does anyone here have one laying around that they dont need? Thanks.
They look like rivet heads but I havent found them yet.
Nor will you. The rivets are press in with tremendous force after the frame rails are stamped and the placed in a jig before final welding. Its not a replacement part.
I take it yours are rusted out and that section missing? Thus needing a front frame section as well. Very few people will have frame section like a front cross member lying around. It would have had to been cut out and separated. IF the front of your frame is that bad, how is the rear?
It's actually not the frame. An awesome PO hacked the front cross member to pieces and I need to replace that part.
$210.00
  100.0%
