D300 not shifting
truk820
Having some problems shifting my Dana 300 twin stick. All of the shift patterns I see indicate, from the front position to rear position, L - N - H for both axles.
The rear, left shifter, won't budge. I believe it's all the way back, indicating it's in H. I've dug around in previous posts and dried unlocking the hubs, budging a foot or two forward and in reverse and trying again, shifting at a few MPH...nothing. Won't move.
The front axle (right shifter) WILL shift, but only one position forward. Here's the funny thing though: I took the shifter boot off and can see the axles engage, and with the stick pulled ALL THE WAY BACK, which I believe would put it in 4WH, the front axle is NOT engaged. This leads me to believe I'm running in 2WH (left shifter back, in rear H, right shifter not engaged, in N). When I push the right stick forward the front axle engages and it gets boggish, which I think indicates it is in 4WL.
So two questions:
1. How can I get everything to shift??
2. Why is the front axle, when pulled all the way back, in N and not in H? Could I potentially have a different shift pattern or different Xfer case?
So two questions:
